although a good engineer would have gone into the boiler program and adjusted it for you ( I would have )
As far as I can tell the installer left all the settings at their default values. Setting D.36 controls the hot water flow sensor. At the moment the value is 0. Does this setting affect the l/min of hot water the boiler produces or is it the flow rate at which the boiler will start heating the water?
I have read previous posts regarding TRV's. When mine were originally fitted (19 years ago) I recall the installer telling me they worked best with the valve fitted to the return side of the radiator with the head horizontal. The advice now seems to be that they should be on the flow side. As mine always worked well with my old boiler, I am not inclined to replace them and think the flow and return connections to the boiler should be reversed to take account of them being one-way flow. Despite all the valves working well, given their age do you think they are living on borrowed time and it would be prudent to replace them?
