Hi All
I had combi boiler Vaillant 843 installed recently together with internet gateway VR 920 and multiMATIC VRC 700/5. Above configuration worked as planned with VRC configured as a standard room thermostat and could be controlled via VRC700 app.
In the next step I added 3x ambiSENSE thermostat valves to radiators in the bedrooms upstairs.
After adding them to the system via VRC700 app I lost access to multiMATIC vrc 700 - is no longer visible in the app. Also it looks like settings on the ambiSENSE have priority over the multiMATIC - when I change requested temp. on the vrc 700 it go back to the value from ambiSENSE after couple minutes so at the moment I don't have heating downstairs unless one of the ambiSENSE TRV is calling for heat.
Question is - can I still use VRC 700 as a standard room thermostat to control temp. downstairs ?
If not - how can I make it works ?
I don't mind that some radiators downstairs will get hot when ambiSENSE upstairs is calling for heat.
I suppose I could buy another ambiSENSE TRV and simply place it somewhere downstairs without even installing on the radiator, but maybe there is better option...
kind regards
Pawel
kind regards
Pawel
