Hi!
Can the people in the know here help me out?
I have noticed recently that the DHW out of my old (trusty) Vaillant VCW 242 EH combi compact boiler is not coming out as hot as it did. I have just replaced the diaphragm pump as I got one really cheap (the old one had the split plastic elbows). I haven't measured any temperatures but just on feel, the water into the DHW heat exchanger (old black cannister type) is absolutely scorching, and the water out not! Diverter valve is fine as NO hot water is getting into the central heating side of the system. And the flow rates have been all adjusted down so there isn't too much water flowing through!
So, aware that fiddling with the old heat exchanger will probably cause it to leak, I am thinking of getting one of the newer ones. My question is, do I need to get a kit with different pipes????
I have seen advertised just the heat exchanger and also heat exchanger with pipe set. Do I have to have the pipe set to convert from the old black plastic cannister type???
Many thanks!
Phil
Many thanks!
Phil
