We had a new valiant eco tec non combi fitted by a pro firm 3 yrs ago (existing CH system is approx 30 yrs old) , system was power flushed by installer according to their invoice and fitted with magnaclean.
Boiler has never worked 100% ie keeps cycling due to (according to subsequent heating engineer) circuit obstruction. Cycling in our case = boiler temp climbs fast and clicks off so CH water never gets really hot - sorry I may not have right terminology here.
Valiant have replaced HE free of charge under warranty. Its still cycling.
Since then I’ve had all downstairs rads off walls and mains flushed them through in the garden also flushed through all downstairs rad feeds from upstairs until water is clear - lots of black filth came out. I had 2 microbore rad elbows blocked with rust during this.
Boiler still cycles and a further engineer says the new HE is part blocked ( 6 months old)
We have a 20 yr old copper DHW cylinder ( engineer has said it may be part blocked) and gravity fed showers with feeble flow, also CH downstairs is 8mm microbore, upstairs is 15mm pipe. According to some people, Valiant HE has very narrow pipework that clogs easily and the boiler is not suited to any system unless that system is in mint condition plus microbore pipe is not doing it any favours.
Diverter valve for CH and DHW has never worked properly in 12 yrs and despite 2 new pro fitted valves doesnt work to this day so DHW via boiler doesnt work 100% and we use immersion 24 hrs.
I’m thinking of cutting my losses, installing a combi and chucking the 3 yr old Valiant boiler away as I can then choose a boiler that is more suited to an old system, I can install showers easily that have good flow and I can do away with the copper cyl.
I should have had a combi in the first place.....I should have called original firm back again but didnt at the time (due to various reasons) and now its too late to do so...
I’m baulking at doing this due to paying £2k 3 yrs ago and prospect of another £2K for a new combi now.
Any observations, suggestions or advice welcomed re. the above dilemma.....
