- Joined
- 25 Oct 2019
- Messages
- 3
- Reaction score
- 0
- Country
Hi all, I am trying to install a Drayton Wiser and as far as I can tell the wall plate is the exact same as the Hive one.
I had a Honeywell RT T6360B installed and I thought it would be simple to replace but I cant get the Drayton Wiser to work.
Can you let me know if I need to run additional cables from the boiler?
As I stand, I removed the L brown cable from the T6360B and connected it to the Drayton L terminal.
Took the N blue cable from Honeywell and connected it to N on Drayton. Earths to the earth on Drayton.
I also put a jumper from L to T1 on the Drayton as the manual said it needs a link to power terminal 1. IS THIS TRUE AND CORRECT??
From Drayton manual:
"Note that the output contacts are voltage-free, so power needs to be put on to Terminal 1 either by linking from Terminal L or from a separate supply with a 3A fuse"
I got nothing running to 2,3, or 4 terminals.
From another thread I read it seems i need to run some cables to the 24v RT inputs of boiler Can anyone please confirm?? Should use the 24v even if Drayton says its Volt free? Should i Leave jumper on Burner OFF in boiler side?
All connections photos below.
T6360B Configuration
Boiler current connections
Drayton Manual
Drayton Manual
