- Joined
- 1 Sep 2015
- Messages
- 368
- Reaction score
- 5
- Country
Quick question on re-converting our garage. Its a single skin brick wall, however the plan is to insulate with solid insulation, and then plasterboard on top, however i need to bring the walls in a bit to get over the block nibs.
Is the correct order Brick - Insulation - Stand off framing - Vapour Barrier - Plasterboard?
Trying to figure out if I need a vapour barrier with foil backed insulation board, if I can simply use foil backed plasterboard, or if to just attach plastic vapour sheets to the studs and standard PB on top
