Vauxhall Combo Van Reversing Sensors
14 Mar 2008
West Midlands
Hi
I've a Combo Van fitted with reversing sensors; However they're not working; Any Ideas??
They usually "Bleep" as soon as the vans put into reverse gear, but not anymore!
dirty sensor / fuse failed
Hi
Although I'm a gasman, I have basic electrical knowledge;
There's a fusebox under the passenger seat, would it probably be one of them? or the 1 in the engine?
Also, would measuring resistance across them using a multimeter therefore suggest blown fuse?
is it a factory fitted system? follow the sensor cables and see if there is a control unit somewhere near the back of the car,you may be able to check its getting its 12v feed when you select reverse
