1) Boiler make / model (gas or oil)
Gas - Myson Orion
2) What is / is not happening
two tanks in the loft, a hot water tank in the airing cupboard & a boiler on the ground floor.
one of the overflows for the tanks just drew my attention to the loft, so I went up to see if the ballvalves were stuck. both tanks were an inch below the overflow pipes
Where did the overflowing water come from? (I suspect another pipe which joins the overflow pipe.
Incidently the tank is now warm - could it have been warm water venting from somewhere into the overflow & thus into the 'cold' tank?
3) Has ANYTHING else been done / changed recently
No
4) When did it (problem) start
Last night 6-ish
5) When does it happen? eg, heating coming on or going off
1 event
6) Anything else you feel may be of relevance
sadly - no
Gas - Myson Orion
No
Last night 6-ish
1 event
sadly - no
