Hi everybody,
Help required please!
I have a Veritas 8 alarm and recently had new Upvc doors/windows fitted. The fitters did not put the door contacts or shock sensors back on so i have done it myself. However, the door contacts were flush and i have swapped them for surface mounted magnetic reed switches (from Maplin). The first problem i had was that the tamper light was on and no response from panel. I removed the mains power and changed the 500ma fuse and all seemed well. When i came to wire the door contacts, the existing cables to the main door were wired as follows:
Green & Yellow twisted together and connected to one terminal on flush round contact.
Blue to separate terminal.
White to separate terminal.
When i came to connect new surface contact, it was pre-cabled with a Red, Black, Blue & Yellow wire, how do i connect up please?
On the back door contact (old BIG! contact!) this was connected to a shock sensor on side window. It was connected as follows:
White into shock sensor then back out to door contact.
Same with Blue.
Green & Yellow not connected in shock sensor but twisted together and connected to one terminal in door contact.
Red & Black to seperate terminals in shock sensor but not connected in door contact.
The new contact is pre-cabled as described earlier.
How do i re-connect new contacts please?
Sorry for long post but couldn't think of any shorter way of explaining myself.
Many thanks in advance,
Gary.
Same with Blue.
Gary.
