Woody (or anyone with a vertical radiator), did you fit this radiator, if so does it function OK?
I've just had one delivered and I'm also surprised to see no baffle / block. I'm wondering weather to fit it as I wouldn't have expected it to work well vertically.
Why not? Hot water rises, so as long as you fit it the right way up it will be fine.
When you first turn on the heating, feel a normal radiator at the bottom. Only a couple of inches around the valve gets hot before the top edge gets warm.
Not sure, maybe with a really high flow rate it would help.
To be honest theoretically radiators should be fed at the top either end and the return should be at the bottom in the middle. Then the water would sink as it cools then drop out at the bottom. But for either simplicity or neatness we don't bother.
@John D v2.0 the older generation on here will remember the twin entry radiator valves, where both pipes went into the same valve and a length of plastic tubing was inserted into the flow and pushed through the bottom of the rad , worked great till someone took the rad off to decorate and dint know there was a tube to re-connect
