A visit from Ariston has solved my identical noise/vibration problem.My plumber had installed the expansion vessel using the flexible pipe supplied connecting it to the 6bar valve. The Expansion Vessel was fixed to the wall using the supplied bracket with the flexible pipe connection underneath.The vessel was lower than the conection to the safety valve.Ariston say this is incorrect as the expansion vessel will have air trapped in its lower part, beneath the diaphragm, and this causes the diaphragm to vibrate when hot water is drawn off.
It has been repositioned below the 6bar safety valve connection with the 22mm connection now uppermost. This has solved my problem.
