If running cable for a ring main, when dropping down through the ceiling and then vertically down the wall to feed a socket then back up again:
1. Do you have to use plastic conduit?
2. If yes, do you have to clip the cables or can they just rest loose inside the conduit?
PS Whats the difference between white cable and grey cable when they are both labelled for the same application???
