Very Warm Water in Cold Water Tank in Loft
8 Oct 2006
Hi all
My father is worried about the above problem
Hes noticed warm water in the cold tank in the loft
Any idea what could be the cause of this?
Apparently they put the water on to warm and also mentioned the overflow pipes had water comming from them I think (not 100% sure)
They have a back boiler type system if that helps which I think then warms the water and is stored in one of the bedrooms
Have no idea why the loft would have warm water in it
Any recommendations in laymans terms what could be the problem ?
Thanks for any pointers
No I dont think the cistern is lagged at all
The only thing I think that is lagged is the hot water water storage which I guess is 6ft or so below the cold water tank
Is there an immersion element in the top of the cylinder? is it turned on?
If yes to both then it has failed and needs to be changed ASAP.
Andy
The cold water storage cistern should be insulated, as should the pipe work within the loft area. Also the underside of the cistern should be seated allowing for air to circulate below. This will help prevent undue warming.
