Your local authority or county will likely have an online road design criteria document containing all the relevant info, you'll need to track it down.
In England the visibility is taken from 'x' - which is measured 2.4m from the kerb edge. Anything in the line must be less than 600mm high. The distance depends on the type of road and speed limit. Of course, NI may be different?
