Vokera 20/80 R.S Flowmatic - no hot water/no heating
5 Feb 2006
Staffordshire
Vokera 20/80 R.S Flowmatic.
The other day my female mate phones me up and says the boiler is making banging noises and not working.
So I go round and have a look:-
It s not making any more banging noises and the pilot light it still on, I turn the hot tap on and the boiler doesn’t fire, same with the central heating. The pressure was very low so I re pressure it.
When the heating is turned on the pin on the boiler flow switch (under the pump) is going in and the pump is starting.
When hot water is requested the pin on the 3 way valve in front of the heat exchanging is going in. And the pump starts and the pin under the pump goes in ( as above)
But nothing is happening with the boiler firing.
It also appears to be leaking water outside to the external pipe, and it’s also been losing pressure for a round 1-2 months. (Probably due to the leak)
Anyway, the next day my mate speaks to a bloke who came to look at the gas meter which had been making clicking noises; he has a look and removes something and puts it back (she doesn’t know what) and bingo it kicks back in. She is not sure if he actually replaced anything; he didn’t charge her anything and was only there for 10 mins.
He also pointed out that the fan is not running on the slow speed setting?? I thought this would cause the pilot light to go out?
Any help would be much appreciated.
I replaced the diaphragm (part 0226) in the DHW manifold last year and cleaned up the pin, as there was no hot water when a hot tap was turned on. Been fine ever since.
I have bought the diaphragm (0557) for the boiler flow switch (the one under the pump) figuring that may fix the leak.
But as it is now working I’m a bit loath to touch it. But I don’t want to leave her in the lurch if it does pack in again.
Cheers.
Pump flow switch is sticking(bottom left)
When the pump starts the pin should move out and make the micro switch then when the pump turns off the pin should retract allowing power to the slow speed fan supply.
Thing is if the pin is stuck out then the boiler will still work but you will get no slow speed fan and you may suffer from intermittant pilot outage from over heating but if its stuck in then the fan would run but the boiler would fire up.
You need to check again and see exactly what its doing and bear in mind this might not be the main reason why its not firing
Stan
I am impressed by the helpfulness and knowledge of the meter fixer!
Most would shrug their shoulders and say "nothing to do with me, I only fix meters".
I am disappointed that your friend did not apparently give him £20 for his good deed!
Tony
I think if you met her you would be VERY HELPFUL as well.
Most blokes are always trying to do her a favour, for one in return.
My sort of customer then :LOL:
pannierstan said:
pilot outage
My secretary sent a bill to a customer with pilot OUTRAGE on it.
They were so scared by that they would not use the boiler untill I explained the error.
Dave
I had a letter from a lady in the bank asking me to "bare" with them!
