The pressure gauge on my Linea 24 combi is losing pressure over period of a few days. (From 1.5 to 0.2bar)
There are no signs of leaks and the Safety valve discharge line is bone dry.
I have taken the covers off boiler and inside the combustion chamber at the rear the side insulation panel is a rusty colour and has perished (almost like a brittle scale), its not what i would call excessive only at the back of the insulation panel on the left side. However there are no signs of water when i felt around this area on the PHE so not sure if this is a sign of the water boiling off inside the chamber or if the boiler flame itself has caused this condition. The front of the insulation panel is like new as is the right hand panel so its not obvious to me if the PHE is leaking. I have left the boiler off for a few hours and the pressure seems to be holding ok. So it seems when cold and not circulating i do not lose pressure, its only once its fired up and circulating.
For the past year i have had to top up every couple of months but the problem has got worse wher im now doing it daily.
Any assitance would be greatly appreciated.
Many Thanks
Chapo 63
Many Thanks
Chapo 63
