vokera option, no central heating
25 Dec 2010
Yorkshire
hi can anybody help. i have a vokera option combi boiler that is over 6 years old. probably quite a few years older. the hot water is fine and fires up however the central heating wont work. it trys to fire up and does but shuts off after about 6 sec. it will continuously keeps trying but fails. ive fiddled about with the thermistor and it trys again to fire up but still no good. i can hear a noise build up for the few seconds after the burner has lit up but then it konks out. ????
Well I think that it has a fault!
But exactly what would require me to see how it works and do tests on it. If the flame burns for six seconds it may be a lack of flow.
Are the rads and the isolating valves all open?
Tony
It could be flow (circulation) problem even though the HW is ok.
any chance that the boiler could actually be alright and its just blocked with sludge. bleed the rads again and some of the water is dirty. however is that just because its not circulating. the first rad is sort of warm. water obviously only pumping round for them few seconds each time. the water from the pump seemed quite dirty as well. i still have no fault light.
