VW Golf blocked rear washer nozzle.
18 Aug 2007
Cheshire
My Golf seems to have black bits in the washer system which rewgularly blocks the nozzles.
The front ones are easy to get at, remove and blow out with an air line. the rear less so. How do i get the nozzle off the rear?
probably by removing the tailgate trim panel to access the pipe.
be carefull when blowing through with compressed air though as vw use push fit connectors to join the pipes along their run, they can seperate and cause you more work!
A common problem is these connectors coming apart due to frost etc and they are in some really unusual places.
Try a pin and keep working the pump?
