I want to avoid unsightly wires by wiring my wall fire directly into a fcu which will be positioned on the side of the chimney breast. I will be taking a feed for this fcu from the nearest socket on the ring. The fuse in the supplied plug (which i will be removing) is 13A.
my question is can i mount the new FCU on the plywood (4mm) that has been used to cover a large hole on the chimney breast, and feed the flex into the chimney up to the fire. if yes, what type of backbox can i use?
thanks
thanks
