Hi, new to this forum.
I have a Bosch WM part# WAS28466GB/10, with a failed motor, stripped motor down,checked motor toc, its open, so removed from the backplane.
bypassed it, cleaned all parts, and then wired motor in series, ran up at low volts on bench.
All good kept volts below 100v to avoid runaway.
Now need the toc to complete the repair, part # is 15AM213A
Anybody know where to get one, or maybe a direct equivalent, its rated at 13A 250V 80ºC.
thanks.
techscot
update
wired in temp thermal safety and tested machine, found a 15AM (parted out other wm)
after extensive testing (2wks) stripped motor, soldered the 15AM in and rebuilt motor, ( note: ensure stator coils go back same way, if not the motor will run on the bench, but not run in machine. if, when testing, the current is high then the stator windings are reversed, stripdown and reverse)
fit new brushes, and run them in on bench
test on bench all good
machine is now fixed and back in the laundry room.
thanks.
techscot
update
