washing machine water cuts off
16 Oct 2006
Lancashire
hello, my friends washing machine,beko WM6143s, if put on a spin only, works fine,door locks, spins, unlocks, turns itself off. When trying to run a wash programme, door locks, water enters for 5 seconds then stops dead, the lights stay on but nothing moves, but no more water, if i turn the machine off and on at the machine switch, it repeats the water situation. Iv'e had a look at the board pcb, all looks clean...(i know means nowt..) anyone please?..
havent got a clue either
but my new machine fills on the "A" part off the drawer first for about 10 seconds then goes on to the "C" section for a full wash so assume "A" is possibly for a prewash in the cycle so momenterally operate when no prewash required
just wondering iff you have a quick prewash fill but the main valve isnt operating with open circuit or dead solenoid
Sounds like possibly the pressure switch is not operating, check the pipe between the pump housing is not blocked by blowing up or down it & that the switch operates. Also pump housing maybe partially blocked.
When swapping wires over on the valves, the other then operates the same, for about 5 seconds...i would assume that they both work?
The pressure switch, i took off the rubber pipe, it's clear, and left it off the switch so it cannot send a "stop filling" message....
Are there only 2 wires to the pressure switch, I would have thought there should be 3. Normally open, normally closed & common so that it needs both to work properly
No you did not give the wrong impression, it is just that your presumption that leaving the pressure switch inoperative means that it is not faulty is flawed. You really need to test it with a meter to check it opens & closes as it should.
