water tap - low pressure?
4 May 2005
Hi
I am a complete plumbing novice and wondered if anyone could give me an idea of what might be wrong with my bath tap. Basically, the hot tap only comes out as a trickle, despite me turning the tap on fully. This is not a problem I've experienced with the bathroom basin hot tap, or the kitchen tap, so I don't think it is a boiler issue (I have a combi-boiler). Nor is it a problem I have with the cold tap.
Does anyone know what could be the problem and how would I go about fixing this? I am in desparate need of a (hot) shower...
Faulty tap?
Try (if you are capable) of swopping the bath taps.
If problem occurrs on same tap, you will know its faulty and needs attention / replacing.
If still the same check supply. Could be kinked flexi, isolator not fully open or blocked feed or airlock. :D
