Waterproofing Flat Concrete Roof
1 Apr 2004
I've got a flat concrete above my back kitchen and outhouse. I want to waterproof the roof as easily as possible. I've seen some liquids/paints from AquaSeal, at my local DIY store, that you can paint onto a concrete roof. undercoat first then a sealer coat? They also sell a repair mastic to apply before using the sealers.
Does this stuff work, or should I being felting the roof. The roof is 8ft wide by 20ft long with a raised concrete rim.
Any advice will be much appreciated.
Cheers
J
easy as possible - paint it with aquaseal, but be prepared for it not to work!
this is a problem that architects have never really cracked.
mainly because all waterproof materials get brittle with age or uv light.
there is a rather unorthodox solution that is really simple to apply but only works for fairly small roofs. that is to get a butyl liner made to fit the roof - it will mean getting accurate dimensions for the liner. but it is a cheap process and best of all you simply order it and wait.
then slip it over the roof and hold it down with mastic and weight (gravel sand etc). you can even turf it.
if this appeals look in the yellow pages under butyl liners and get them to quote a price - invariably it is shockingly cheap. if you get on well with them they may even help you with the design
