wayrock chip board instalation
22 Jul 2012
Carmarthenshire
I need to fit a new floor i have bare joists now on 400mm centres. the rooms are upstairs and are a bathroom and kitchen. what thickness wayrock do i need to use. Does it need to glued together. any advice tips please
First mistake is don’t use chip flooring, its total crap but an absolute minimum would be 18mm but for a little extra you can get a "proper" floor. I wouldn’t go anywhere near chip, especially for a bathroom or kitchen & if you tile, it will most likely end in disaster!
Some do, some don’t but it won’t make an awful mot of dereference; the end result is it will still be a crap floor!
Use a better flooring material; either T&G timber or, if your tiling that bathroom/kitchen, WBP ply. The thickness you need will depend on your floor joist/size/pitch between 18-25mm.
Thanks will use WBP ply as i need to lay ceramic tiles.
As I said actual thickness you need when tiling depends on your joist configuration. You can generally get away with 18mm in light load/use rooms such as bath/shower rooms but in heavy load/use areas such as kitchens/halls etc, you should go up to 22mm or even 25mm if you want it to last.
