My problem is that I have a siphonic wc pan which was operating perfectly until the diaphram split. Thinking that a new siphon would be a better bet than inserting a new diaphram I purchased a Dudley Turbo 88. Cannot get the siphonic action which I had with the old siphon, the pan fills and then drains quickly but not sufficiently to clear the pan.
The old unit had a insert which fitted into the outlet of the siphon, this had a 3/8" dia pipe which fed into the pan, it will be difficult to describe the unit apart from it being some 4 long the same diameter as the siphon outlet, internally there is solid centre with a gap around the centre plug. The system is some 30 years old
Does the turbo 88 match to the siphonic pan? If yes do. I need to remove plugs etc or should I just throw the turbo 88 siphon in the bin and refurbish the old siphon?
wgd
wgd
