WD420 PCB replaced and...
14 May 2016
Hi all.
I've just replaced my wd420 PCB as I had an eeprom error. Now it seems that there is an F08 error whenever the pump in engaged . But the machine also gets stuck in the wash cycle. I had the back open yesterday , I checked everything. Wires to all components , tested resistance to heater element and it's at 30ohms . I took the pump off and checked all pipes and the pump. Everything clear. I checked the pressures switch and it was working and hose and that was clear . I am at my wits end . Can anyone help me with this?
How and where did you get the new pcb. fo8 is heater relay faulty.
Send it back. Tell them the heater relay is faulty. You can give it a tap sometimes it unjams it.
