Working on a job with a deadline and we are forcast for rain for the next week. We have another 300 8'' blocks to go down. Does anyone have any advice for wet weather blocklaying? apart from wear a raincoat
Unless they're forecasting monsoons or you're working in a trench I wouldn't expect it to be a problem. Put some old scaffolding boards over the wall overnight if the rain's so heavy you're worried about the mortar being washed out.
Laying these things in a heatwave is a much bigger headache.
(Mind you, I've just seen where you're based & I can't speak for NZ weather, but I know it can be pretty ferocious)
Rain is a probelm as it keeps the wall wet, washes out the joints and causes the lower joints to ooze due to the weight - leaving a unstable wall as you try to build higher.
You have to lay a few course quick and then cover them
Having said that, its hardly going to rain for a whole week non-stop is it? You may have to work late or start early, and through your dinner break
Cheers boys,
We smashed the wall out in the wet and chucked some planks over top. Luckily it was only 2 courses high. This is my first attempt at my own buisness and I appreciate the help.
Cheers
Rich
