is it ok to use waterproofer in the scratchcoat while roughcasting roy? or will that kill the suction to much?The last rough casting job I did I used a 6-1-1 mix for the scratch, and gave it a bit of a wetting before putting on my 6-1-1 mix butter coat then threw the r/cast on to that. You don't want to kill the suction for r/casting. Have a look at my photos on my album..![]()
I've never tried it with w/proofer steve and have used same mix for scratch as buttercoat, and 4-2-1-1 for the wet dash mix... It might be ok with w/proofer, maybe one of the lads has tried it and will let us know..is it ok to use waterproofer in the scratchcoat while roughcasting roy? or will that kill the suction to much?The last rough casting job I did I used a 6-1-1 mix for the scratch, and gave it a bit of a wetting before putting on my 6-1-1 mix butter coat then threw the r/cast on to that. You don't want to kill the suction for r/casting. Have a look at my photos on my album..![]()
4-2-1-1 is that sand-cement-lime- aggregate?I've never tried it with w/proofer steve and have used same mix for scratch as buttercoat, and 4-2-1-1 for the wet dash mix... It might be ok with w/proofer, maybe one of the lads has tried it and will let us know..is it ok to use waterproofer in the scratchcoat while roughcasting roy? or will that kill the suction to much?The last rough casting job I did I used a 6-1-1 mix for the scratch, and gave it a bit of a wetting before putting on my 6-1-1 mix butter coat then threw the r/cast on to that. You don't want to kill the suction for r/casting. Have a look at my photos on my album..![]()
stones-sand-cement-lime, steve4-2-1-1 is that sand-cement-lime- aggregate?I've never tried it with w/proofer steve and have used same mix for scratch as buttercoat, and 4-2-1-1 for the wet dash mix... It might be ok with w/proofer, maybe one of the lads has tried it and will let us know..is it ok to use waterproofer in the scratchcoat while roughcasting roy? or will that kill the suction to much?The last rough casting job I did I used a 6-1-1 mix for the scratch, and gave it a bit of a wetting before putting on my 6-1-1 mix butter coat then threw the r/cast on to that. You don't want to kill the suction for r/casting. Have a look at my photos on my album..![]()
For dry dash (roughcasting), you would "always" use waterprofer in the scratchcoat. You don't want there to be "any" suction on the wall when you put on the top coat ready for the chips. If the scratch coat has suction, and even though you wet it thoroughly before putting on the top coat, the top coat will tighten up before you can throw the chips/dash into it, causing them to bounce of of the mortar, rather than penetrate/stick into it.
So to reflect,,,, I would always use a waterproofer in the scratch coat, plus give the scratch coat a good soak down, and allow to drain off before putting on the top coat.
Hi rc, steve was on about if you could put w/proofer in the scratch for wet dashing but I myself have never used it in the scratch (because of killing the suction) what do you think mucka?![]()
