- Joined
- 13 Sep 2016
- Messages
- 18
- Reaction score
- 2
- Country
Hello All
would love some advice if possible.
i have been searching for info but i am struggling to get my answer, and i have looked at so many posts and videos that my brain is fried!
I am converting a downstairs bathroom to a wet room and i have it all sorted except the toilet, i have never changed one before or had anything to do with fitting / removing them.
I have attached some photos on the toilet i will be replacing.
![](//i1031.photobucket.com/albums/y372/edb1984/IMG_2983_zpsql8jx0hr.jpg)
![](//i1031.photobucket.com/albums/y372/edb1984/IMG_2986_zpskaecuroe.jpg)
![](//i1031.photobucket.com/albums/y372/edb1984/IMG_2979_zpsid8klr5s.jpg)
my questions is, what toilet can i replace this with? - my concerns with just buying any toilet is the fact its so far out from the wall, its currently sitting about 62cm away from the wall.
the waste pipe looks to be fixed to the toilet with some form of mortar, it actually feels like plaster, and it is approximately 185mm wide.
also note the inconvenient location of the mains water supply.
if you were replacing this toilet, what would you use and what would you change?
ALSO
i am installing a mixer shower and i am chasing the pipework into the wall, i am having a combi fitted once the bathroom is done so i am using 15mm pipework throughout (correct me if i am wrong) as i believe that 22mm is overkill and more intended for gravity fed?
i was going to use copper but a neighbor said he used plastic as its easier than messing around trying to cover up all the copper ready for cementing back into the wall spaces.
would you use Copper or Plastic for a shower install?
![](http://i1031.photobucket.com/albums/y372/edb1984/IMG_2983_zpsql8jx0hr.jpg)
![](http://i1031.photobucket.com/albums/y372/edb1984/IMG_2986_zpskaecuroe.jpg)
![](http://i1031.photobucket.com/albums/y372/edb1984/IMG_2979_zpsid8klr5s.jpg)
ALSO
