My CH system seems to be full of mud!
Some background: it's a conventional system with a header tank in the loft, gas boiler / pump and a diverter valve to feed hot water to the hot water tank and radiators. I noticed that when the boiler came on I had hot water dribbling into the header tank from the vent pipe. After some investigation I found that the fill pipe between the header tank and the boiler circuit was almost completely blocked. I cut into the fill pipe at the bottom and rodded it through and got lots of very dark brown water out. The header tank also had two inches of brown sediment in the bottom, right up to the level of the outlet.
I've got rid of as much of this sediment as I can, and flushed the system through with tap water, and I'm trying to find something to flush and clean the system properly now. While I was flushing water through the system, several lots of dark brown water came out but mostly what came out was clear water. It seemed that this was a sediment rather than something in solution.
The header tank didn't originally have a lid on, so there's been plenty of time for debris to fall into the tank, but I've taken out literally a couple of gallons of thick goop and it's hard to believe that all managed to fall into the tank. I can't think where else it would have come from though.
Any ideas what it is, also any suggestions on the best way to get the rest of it out of the system? I imagine it's settled all over the place.
