Replacing our fireplace with a Victorian cast iron type. The front hearth will be a granite slab but not under the fire grate. This will be cemented, but what mortar mix should I be using?
Just a sharp or building sand and cement mix, it’s not directly in contact with the fire and sits below it assuming you’re having the usual fire insert and ash pan
