Hello, unless I've messed it up there should be a photo attached of a house with some kind of sheet roofing over the porch and downstairs bay. Id like to know what it is. I assume its a fairly modern material?
Looks like zinc to me - comes in various colours and is joined by machine using "standing seams". A guy called hardmetalking ( hard metal king) used to post here and knew all about it. And did loads of it.
In recent years there's been quite a bit of it installed on modern commercial structures (office blocks and the like). Looks good, ages nicely. Requires a plywood and membrane base beneath it on the stuff I've done
Hello everyone. Thanks for your posts. So is there a chance I can get hold of it or similar. Any point trying jewsons etc. And what about deadening the sound of rain? I need to lay it as a small roof not a wall.
Yes. If it will have to be bossed or whatever the word is or difficult to source or take ages to learn about. Maybe I can find someone to do it or maybe best use slate at 20 degrees.
