I am using 20mm conduit as a sleeve. The wall it is going through is 600mm thick, so before I buy a pricey 1m long sds bit, I wanted to check what diameter to buy to make life easy.
Will a 20mm drill be too tight or should I go for 22mm ?? If I go 22 mm will the conduit be too loose and slide around?
The wall is breeze blocks if that makes any difference.
Many thanks for any advice,
Kevin.
Kevin.
