Hi
In terms of both regs and from a plumbers’ perspective, is there anywhere I should add a non return valve or check / double check valve in a combi setup?
I’ve looked into it a bit, and I see the technical difference between a NRV and single / double check valve but I’m still not sure where I should put any?
I assume one goes between the mains stopcock and the appliances, but not sure which, and also if I should add any others anywhere else for the mains supply or for the CH flow/return circuit?
Thanks for any advice.
