I have to specify a shower pump for a standard bar shower and, possibly, a second low pressure shower which currently works on gravity. The customer is very sensitive to noise so I want to identify the quietest pump available. Any suggestions?
Salamander ESP pumps are pdq. I think there might have been another thread .... I came across a 3 bar one which the tenants didn't even know they had. It was in a cupboard in the hall. I heard it, but they hadn't noticed.
The lower p ones are impressively quiet.
Thanks ChrisR. What's the lowest pressure (least noisy) I might get away with? The tank base height is only about 1.5 metres above shower heads, but pipe runs are mostly 22mm, just last 4 metres in 15mm.
Had a look at prices. ESP range seem to be £400 ish! the RSP range also claimed to be very quiet, but more like £200 ish. Sounds more like it.
