Hello,
Having just bought a whirlpool bath I need to just confirm that the wiring I intend to do is correct.
The cable from the pump is nothing more than 3C+E flex. The pump is rated at 3.5amps.
Im thinking that I will connect the pump into a waterproof junction box on the wall inside the bath space. Then wire into a circuit breaker outside the bathroom, then onto an isolating switch.
Does this sound OK and can I spur off a socket ring main or go straight into the CU and wire into a circuit breaker.
Thanks for the advise.
