My Whirlpool AWM 6120 washing machine no longer takes the rinse aid properly from the tray. It used to leave the tray completely empty but now most of the contents remain after the completion of the wash. The tray has been thoroughly cleaned. The dispenser uses the suction principle and I presume that, as water comes in to the rinse section of the tray, suction draws out the contents. That works when I test the tray. I suspect there is not enough water getting to this section of the tray. I have removed the top of the machine and notice that the plastic section through which the water passes has a strange mechanism of pointers and springs. Could this have moved into the wrong position. I cannot understand what this does.
Any help would be most appreciated.
