whistling pipes
29 May 2005
Hi Everyone,
Two of our toilets (on the same stack) have started making a loud whistling sound when flushed. The downstairs toilet started doing it first and now the upstairs does also. They only do it when flushed. Both toilets are less than a year old. The house was built in 1986.
Please tell me what's wrong and if we can fix it ourselves or need a plumber.
Thank you!
Alice
Plastic ball valve comes to mind change them for brass
obviously noise from when they are filling if you live in a hard water area it could be the down to scale build up in the washers on the ballvalve :rolleyes:
beaniebrain said:
Hi Everyone,
Thank you!
Alice
ang on the poster is in the states
hope they aint whistling dixie ;) ;)
It really does help to diagnose problems if the poster takes the trouble to think about what they are saying.
In this case the toilets do NOT make a whistling noise WHEN they are flushed. They are making the noise AFTER flushing while the cistern is refilling.
I am not sure why DIA suggests replacing a plastic ball with a copper one. I would go for the cheaper option of replacing the whole float valve reusing a plastic ball.
In a few cases a mains fed float valve is wrongly configured as a low pressure valve and becomes noisy.
Tony Glazier
