Why do my 2 port motorised valves not last?
9 Sep 2008
Midlothian
1st valve lasted 7 or 8 years. Second one 2 years. Now another one on a different zone is opening but not sending a live switch signal out. Worked around it by sending the thermostat -on live signal to the boiler so dont need valve microswitchbto work. Any advice on getting valves to last longer.
Best tommy banana
What make are they? Different valves are built to a different standard.
design them out is the best option in my opinion... the ones sold in the UK are a model developed over 50 years ago. In the rest of europe they sell more robust ones working a lower voltages although some are 240vs...
what would you guys recommend as an alternate - either a 2 port valve or a design alternative?
best
tommy b.
I'm using Sauter ones at the moment, detachable head, plug in wiring and a 5 year warranty.
Why would you change the WHOLE VALVE???! :eek:
230v present but valve not opening - new Sychron motor (cheap repair)
Motor opens, but no signal to boiler/pump, New head, but sometimes just microswitch
Valve letting by, fit a service pack (Ball & o ring kit) (cheap repair)
It must be VERY unusual to have to replace the WHOLE valve! ;)
