Wickes £49.99 WC
Discussion in 'Plumbing and Central Heating' started by avidfan, 15 Mar 2010.
  1. avidfan
    15 May 2005
    149
    Thanks Received:
    8
    Sussex
    Country:
    Anyone fitted the above? Been asked to fit one though not keen as I've not seen one. Apparently it comes complete with seat and even fixings!
  2. muggles
    28 Oct 2005
    7,143
    Thanks Received:
    1,154
    Oxfordshire
    Country:
    Sounds like a good deal, what could possibly go wrong!? :LOL:
    Does it have the fill and flush valves included?
    I suspect the following will be a good procedure to follow: When you unpack it, take the pan out and stand it on a level surface. Step back and look at it from the front. Go fetch your level and confirm that the pan really is shorter on one side than the other. Take it back to the shop. Spend ages at wickes unpacking many pans until you find one you're happy with. Have lunch, because by now it will be lunchtime, then fit WC. Charge customer rather more than they expected due to all the arsing about. Have an early day as there's not really time to do anything else
  3. tamz
    25 Feb 2009
    1,883
    Thanks Received:
    278
    West Lothian
    Country:
    Don't make any difference. A pan is just a pan and at £50 inc.seat, i take it cistern as well, you can bet it is shyte quality. It will still work though.
  4. neds
    18 Nov 2007
    925
    Thanks Received:
    28
    Country:
    I saw whole cloakroom sets for 50 notes, they are all much of a muchness. The toilets are fine of the close coupled variety but you may have fun getting the cistern and pan to seat well without leaking.
  5. roguetrader
    30 Sep 2008
    6,097
    Thanks Received:
    2,583
    Suffolk
    Country:
    i bet its better quality than the ridiculous designer back to wall pan and cistern from c.p. harts that we fitted to the 'gardeners rest room' at some posh pad today. £535 + vat. what a load of ****e!
  6. lifesagasman
    20 Feb 2010
    4,986
    Thanks Received:
    33
    Lancashire
    Country:
    cheapies often OK except for the rubbishy seat
  7. gasgeezer
    11 Jun 2005
    317
    Thanks Received:
    3
    Country:
    Fitted one last week fantastic, cistern already fitted took 30 mins to connect no problems since fitted quality good reccommend them.Basically idiot proof
  8. linkyplumb
    8 Sep 2008
    1,362
    Thanks Received:
    169
    Hampshire
    Country:
    The only thing I have found wrong with the cheaper wc complete units, is that when the internals start to fail (constantly overflowing etc), then it is a new flush unit as you can never normally get the spares for them.
    Graham
  9. jono_h
    19 May 2006
    275
    Thanks Received:
    17
    Country:
    Fitted three of the B&Q equivalents. No problems with actual fitting, but have had to tweak the flush button on two when the spring became stuck.
    If you're reasonably happy that you're not going to be asked to repair it for free if it develops a fault then you should be ok
  10. Nige F
    28 Jun 2005
    17,356
    Thanks Received:
    1,018
    Country:
    c.p. harts quote] Is that ryming slang :idea:
  11. avidfan
    15 May 2005
    149
    Thanks Received:
    8
    Sussex
    Country:
    Bit the bullet and fiited said wc today. Pleasantly supprised, not a bad unit. pan has a nice big foot so it's pretty stable and it weighs a ton. Flush and fill valves prefitted and didn't leak. As mentioned, the seats a bit flimsy and the outlet spigot could have been a tad longer. However, for fifty notes not at all bad.
  12. ub7rm
    19 Sep 2006
    151
    Thanks Received:
    4
    Aberdeen
    Country:
    I fitted the B&Q equivalent in my flat last year and was / am quite happy with the quality. No leaks / no hassle. Threw away the seat that came with it without even fitting it.
  13. muggles
    28 Oct 2005
    7,143
    Thanks Received:
    1,154
    Oxfordshire
    Country:
    Sounds like I was wrong then, will have to look at them as potential suppliers for contract stuff in future...
  14. tamz
    25 Feb 2009
    1,883
    Thanks Received:
    278
    West Lothian
    Country:
    That might be an idea :idea: Cheapest i can get is around £75 + for pan cist & seat and still a phishy plastic seat.
Loading...
Share This Page
