Hi. wondering if any 1 can help me with error code f04 ,pressure switch stuck on empty, where is the pressure switch? if I'm getting this code is it best to order a new 1 from part master?
thanks rocks,yeah i found a picture of it on partmaster and sussed it . gonna just replace it . in your experience is that the solution?blew down the pipe and there is no blockage. tried twidling the screws thinking if it was jammed that might free it up , not so . what r the screws for does the posision of the screws have a bearing on the switch? thanks again
