Will 43cm x 27cm corner be ok when installing 2 x french windows
23 Feb 2009
Berkshire
I have a single storey, 3.6 m x 3.6 m outbuidling, with 10 , 4x2 joists running north / south.
I am looking to install two large (identical) sliding french windows in the north and east walls (i.e. - corner orientation, not on opposite walls).
I will put a lintel under the (north) load bearing wall, and am tempted to do the same under the non load bearing (east) wall.
Wondering whether the resulting "column" between the two new french windows, will be ok structure wise (i.e. strong enough). This column will be approx 43 cm x 43 cm on the outer surface (basically 2 x brick widths each side). The wall thinkness is approx 27cm. Will it be strong enough ?
The only foot traffic on the roof will be the occasional wander round for maintenance (and , maybe one day, re-roofing).
Will the "column" be strong enough ?
The remaining brick pier will be fine to take the vertical (gravity) load, but whether it would stand up to repeated opening and shutting of heavy glazed doors.........?
Hmm - interesting point. What would need to be done to strengthen things ?
[ Also I've now decided on 2.5 bricks each "width", so 50cm x 50cm (as opposed to 43x43). The construction is "typical" brick and block cavity wall, i.e. brick outer, aircrete block inner (with cavity) ]
