I have put two new lights in a room, they both go to a double switch. One light causes the MCB to pop when the light switches on. After further investigation i found it only happens when the earth from the switch cable is connected in the ceiling rose. Therefore i have come to the conclusion that the earth cable is coming live when the switch is made. Can i just cut the earth back in the ceiling rose and not connect it? I can earth the switch box because i can use the earth from the other light. Will this pass an inspection? I dont want to have to chase the cable out as just had it plastered.
