window sill -Glue ?
31 Dec 2007
London
Hi
I've been decorating the outside of a house and 2 of the window sills (plastic) have fallen off (before I started). The lady wants me to put them back but not sure of the best way.
It looks like they were put on after the windows were fitted as they butt up to wood which the window sits on. Each end is sunk into the wall. Guessing they were glued in originally.
So what would you use to join the wood and plastic together ?
An Epoxy, EVO-STIK 528 ADHESIVE, normal contact adhesive, no nails or something else ?
thanks in advance
is it better than EVO-STIK SERIOUS STUFF. All looks the same to me !
Ive not tried that Evo Stick, but the Sticks Like **** doesn't smell, or need applying to both surfaced and leaving for 5 minutes or anything like that.... squirt it on, press surfaces together, cured in 24 hours
