I am hoping to commission an electrician to install an extractor fan (operated by humidistat sensor only, I don't want it to come on with the lights) and a mirror with lights in our bathroom.
As we are going to change from the existing electric shower to a shower run off a combi boiler I will be asking them to decommission the electric shower as well.
The existing electric shower was installed by an electrician about 15 tears ago.
It has its own 45 amp fuse in the consumer unit and a very thick grey cable runs from the consumer unit to an isolation switch outside the bathroom door then under the floor to the shower.
Will they be able to use that cable/isolation switch for wiring either the extractor fan or mirror with lights or both.
If yes then I could crack on with replacing floor boards over the bank holiday (hurray!), I would like not to have to remove them again if the existing cable has to go and new ones put in.
Thanks in advance for any help.
