Hi
I have just been attempting to wire up a ceiling rose light. I copied how the old light was wired up onto a piece of paper and then when I wired up the new light I actually left on the old rose and placed it over the top (it was a chandileer type light) and used the notes to wire up the new light, the light was controlled by a dimmer switch.
However I have a bit of a problem, when I connected the power, the light cannot be controlled by its dimmer siwtch in the dining area and will only dim when I adjust the living room lights, which in turn are just barely on when the dimmer is on full.
Looking at the forum wiki, I think I realise my mistake, namely there were three bunches of wires coming down into the ceiling rose and they should have been wired up in a certain order, but I didn't realise this at the time and wired the coloured wires into the right blocks but didn't neccasarily put them in the right holes.
Is there any way I can tell which wire bunch needs to go into which hole on the block?
