Wiring a Fan Isolator Switch / Or Fuse unit - Please Help!
kjm
13 Dec 2003
Hi I wonder if someone can advise.
My bathroom currently has a fan and spot lights. Both appear to be wired in to a Fuse Unit on the wall. ie if I prise the fuse out with a screwdriver both the fan and the lights cut off.
Is there any way of replacing the fuse with something where I can turn the fan off but keep the lights on?? ie a Fan Isolator Switch or a Switched Fuse Unit.
Please could someone advise.
The fan obviously needs the fuse, but do the lights? How should I go about this, and is it possible.
I have 3 Red Wires 3 Neutral and 2 earth.
Kevin
Kevin
get a fan isolator and put this between the spur and fan
