- Joined
- 27 Jan 2008
- Messages
- 23,695
- Reaction score
- 2,670
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
There are models with remote sensors, however mine simply have two sensors one for air and one for water, the latter auto compensates the air temperature reading, and the radiators are modulated just like the boiler, so other than first turn on with a cold house, they are not that hot, unlike the old mark/space control, the modern system regulates the output so neither boiler or radiator valves switch on/off both gradually reduce output.Do the electronic ones have remote sensors (I didn't think they did)?
I have no experience of electronic ones, but I've often looked at all my non-electronic ones and wondered how on earth they even vaguely do what they are meant to do, since their heat sensor is usually sitting just a couple of inches away from a radiator which, when 'working' is virtually too hot to touch and, indeed, whose bodies are often pretty warm (probably warmer than the desired room temp) after the CH has been running for a while.
Kind Regards, John
The problem is although there are thermostats like EvoHome and Nest which use an industrial standard opentherm many boilers can only have the output modulated by either return water temperature or that manufacturers own modulating thermostat the latter may not be able to talk to electronic TRV heads. So in mothers house with a Bosch boiler if I used EvoHome it has to be set to use the mark/space ratio not modulate the boiler, it needs Bosch's own thermostat think it's call Wave to electrically modulate the boiler.
