Wiring expert needed
26 Nov 2007
Buckinghamshire
I installed a rear view camera kit on my car, it works fine whilst the gear lever is in reverse, but am not sure if the connections are what they should be.
Although the advert fotos give connection Info, I got conflicting info from ventors:-
1. please check the MONITOR other RED ANG BLACK WIRE whether CONNECT WELL WITH CAR POWER or not.
2. The CAMERA RED AND BLACK POWER CABLE NEED CONNECT WITH PARKING LIGHT POSITIVE AND NEGIATIVE too So it can work auto when you parking only
3. I SEE, THE BLUE WIRE YOU CAN CONNECT OR NOT,
BUT IF YOU CONNECTED, THERE WILL AUTO TURN ON ONCE YOU PACKING
The Blue wire from the monitor, in the fotos, makes rear view to appear if it is connected to the (+) of the reverse light, whi
The schematic wiring a drew in my fotos shows how I connected it & works OK
Can anybody work out what is the correct way & provide me with a proper wiring diagram? ...thanx .....nick
PS Please see uploaded fotos on this in "show my pictures"
I cant find the printed wiring diagram you got with the camera, otherwise we're guessing.
It you get it, post it up and we'll have a wee look for you
You have an air pump in the circuit diagram with no fuse on the supply wire (positive) from the battery. Might be best to cut it and insert a fuse holder/fuse.
