Wiring New wall switches
26 Apr 2008
Cheshire
We have two ceiling lights in master bedroom (both are offset to room centre)
One is wired to a wall switch and the other is on pull switch above the bed; they appear to be on independant circuits.
We want to have only one light in centre of room which we can switch on from a wall switch by the bedroom door and to also install two wall switches either side of the bed so we can switch on and off when in bed.
Easiest way appears to remove the pull switch circuit completely and then relocate the existing ceiling rose which is connected to the existing wall switch.
How do I wire in two new wall switches with the existing wall switch so that the light can be operated on/off from any switch?
In removing the existing setup you will need to ensure the circuit remains complete, i.e. by using a junction box if accessable or you may need to replace or re route some of the cables. Can you upload some pics of the existing wiring?
For the other light:
You should have some wires in the back of the existing switch at the moment connected Com to L1.
To do what you want you will need 2 x 2way switches and 1 x intermediate.
The existing switch needs to be swopped to a 2 way, the existing switch wires going to L1 and L2. The "strapper" wires then interlink to the intermediate switch and then onto the other 2 way switch, as shown in these diagrams: //www.diynot.com/wiki/electrics:intermediate#diagrams
Sorry cannot supply any pics, loft is boarded over so will have to start pulling that up when I begin
Anyhow, the link you sent is clear as to what to do and your text is clear
Replace current wall switch with 2 way switch
One bedside switch is the intermediate and the other bedide switch is a 2 way switch
BTW my current circuit does not appear to have any earth wire in it; do I have to buy 4 core cable and pull this through off exisitng wall switch or can I use 3 core and use the earth (suitably marked up) so as to connect L1 on intermediate to L2 on 2 way switch
Thanks for the help
How much of an exercise is it to replace the length of cable back to the consumer unit?
Big job, would have to take up half the loft boards then come through airing cupboard, under bathroom floor and then down through kitchen wall and into stair cupboard for consumer unit.
Was thinking of trying to pull through new cables by attaching to the old ones
Are you sure? Why would someone do that?
Or replace the current one with an intermediate and have 2-ways by the bed, if that makes selection of the bedside switches easier. I did it that way because I wanted architrave switches each side of the bed, and I couldn't find intermediate ones.
Ideally rewire it, but until you do you must not use metal switches or light fittings which require an earth.
You will need 3-core & earth cable.
Hmmm. Unlikely. Are the existing cables in conduit?
What i mean is the pull switch operates one light and the wall switch operates the other light; they are probably connected back to same point at some place
Yes, I can use the intermediate on wall and 2 x 2 way by beds (better idea)
Rewire; would mean running a new cable all the way back to consumer unit, does that mean I will then have to re-wire all the upstairs lights with new cable
OK, bad idea, 3 core and earth it is
Some of wiring is in conduit
OK - if it's wired with loop-in at the ceiling rose/fitting then removing a switch is easy.
If you want to use metal switches, or lights that need an earth, yes.
And the same will apply to downstairs.
You might be able to pull new wires through with the old, or they might come apart or get stuck part way through the process and leave you with no lights.
BUT - before you start doing things like that... it's been a long time since lighting circuits had to have an earth. If your wiring is that old you might need the whole lot replacing - you should have it all properly inspected...
